GTI Engine/ extracting maximum engine power
phantom75
i have done 2500 kms up to today ,it is nearly impossible to drive my GTI in a civilised way, i cannot resist benifiting from it's full engine power most of the time, can anybody advise if this is dangerous and may hurt the engine on long terms? is the engine equiped for this? the RPM is always on the higher side and almost reaching the red area between every gear, whoever is driving this car may understand what im talking about, so any threats on damaging the engine because of this????? confused.gif
Agreed, Red. So long as you keep sufficient oil in the car and a decent amount of tread on your tyres it shouldn't cause too much damage, although it may accelerate your service schedule somewhat (the oil will become contaminated quicker), and it may need more components replacing in 8-10 years than a more gentlly driven car.
Even non-DSG cars shouldn't suffer excessive damaged by reving the engine too high as all cars have rev limiters these days specifically designed to stop people reving the engine "to death". DSG-equipt cars have the edge though as the transmission will generally try to shift up before it hits the redline.
Andy's point about temperature is very important - I forgot that! No longer necessary to idle for a few minutes before switching off ignition for the sake of the turbo as in older cars. The unexpectedly rough sound on first starting or idling is normal. If you find the engine generally too quiet as a driving aid then consider a Milltek exhaust which will boost performance as well.
the GTI's are put through very rigorous engine testing a the factory anyway, way before you get it.
I read an article on the Veyron somewhere that said it had to undergo the same bench testing as every other VAG engine - 3 weeks solid flat out! 169144-ok.gif
