ocrp Posted December 15, 2005 Report Share Posted December 15, 2005 How do you change the angle of the spary, vertically and horizontally? I'm used to the standard nipple ones, on my previous cars, which you could adjust with a pin. These are mounted under the bonnet lip, very hard to see what's going on... Link to comment Share on other sites More sharing options...
Keble_Martin Posted December 15, 2005 Report Share Posted December 15, 2005 Mine were non-adjustable...they worked just fine. Pressure problem, perhaps? Link to comment Share on other sites More sharing options...
ocrp Posted December 18, 2005 Author Report Share Posted December 18, 2005 Pressure is fine, the aim is out! One is too low, the other too wide. Link to comment Share on other sites More sharing options...
Wobby Posted December 18, 2005 Report Share Posted December 18, 2005 Easiest way is to put in a wider screen! But mount it lower down. Link to comment Share on other sites More sharing options...
felixthecat1 Posted December 20, 2005 Report Share Posted December 20, 2005 [ QUOTE ] Easiest way is to put in a wider screen! But mount it lower down. [/ QUOTE ] Bad man. I don't have a Passat anymore so I cant physically check but it should be possible to insert an needle in the offendng jet and gently adjust it to a better aim. As I say I can't check this but I have done it before on another car. Don't be rough with it though as you run the risk of making the hole wider which will reduce the water pressure resulting in a weaker spray. Link to comment Share on other sites More sharing options...
ocrp Posted December 20, 2005 Author Report Share Posted December 20, 2005 Thanks for that. Will give it a go. Not sure why they cant put these things in the manual. Link to comment Share on other sites More sharing options...
NunchukHamster Posted December 20, 2005 Report Share Posted December 20, 2005 It's not just the nipple bit that moves, the entire rectangular piece of plastic the nozzle is set into moves up and down to adjust the angle. Link to comment Share on other sites More sharing options...
ocrp Posted December 20, 2005 Author Report Share Posted December 20, 2005 Only very slightly, not enough to make a difference. I think I'll have to go down the needle route. Link to comment Share on other sites More sharing options...
