reset fuel computer
banny
There should be a rocker type switch on the end of the windscreen washer stalk.
If you rock it up and down it will scroll through the options.
Underneath the same stalk you should find a button that pushes into the stalk a little bit. This scrolls from long term (2) and short term (1) data recording. (1) and (2) are shown on the dash during certain option choices.
If you push and hold the underneath button it will zero the display you are currently on as long as you are on one of the options which show either (1) or (2).
Hope this helps. This info is for the 2000 - 2005 (old) models.
