Advent Posted January 20, 2006 Report Share Posted January 20, 2006 I've noticed the clutch gentley vibrating at times when driving, usually before I change gear. Problem or normal? Also the accelator dips a little (i.e. revs without my foot on it) for a second just after I change gear. Are these two things related? Link to comment Share on other sites More sharing options...
Advent Posted January 21, 2006 Author Report Share Posted January 21, 2006 Any ideas? Link to comment Share on other sites More sharing options...
Advent Posted January 26, 2006 Author Report Share Posted January 26, 2006 Anyone? Link to comment Share on other sites More sharing options...
cosmicblue Posted January 26, 2006 Report Share Posted January 26, 2006 As a general rule clutches don't vibrate to the extent that you can feel it because the clutch cover/pressure plate is bolted to the flywheel and spins at engine speed. The clutch disk/drive plate is on the gear box input shaft and that also spins pretty quickly. Perhaps you have an engine mounting on its way out? Link to comment Share on other sites More sharing options...
doogal1972 Posted January 27, 2006 Report Share Posted January 27, 2006 If you rest your foot on the clutch pedal or maybe dip the clutch pedal a tiny amount you will feel a real vibration through the pedal. This I think is due to the dual mass fly wheel and is a characteristic of the car, I've been told. The accelerator problem, I have no idea. Link to comment Share on other sites More sharing options...
