[Audi A3/S3] xenon to bi xenon?
seaco
no its not, the bulb remains the same.
its an electrically operated shutter mechanism in front of the bulb.
so the whole module holding the projector is different, along with internal wiring.
when you flick on main beams the shutter moves electrically via solenoid to change the beam pattern. whilst the bulb stays on all the time.
usually backed up by a main beam halogen.
Halogen is there to add light, and also to the headlight flash bit when the xenons are off.
Adaptive lighting just moves up down/left to right and is very articulate. Usually paired with a cornering light.
I think somone made speed sensitive lighting as some point
ie 30mph short /wide beam,
hurtling along at 60+ long narrow one.
i can oly assume some sort of iris or apperture was used.
