Server Purchase Advice
mb
Hi - I am about to comission a new server - it will run 2003 Server & SQL 2000/2005 as well as file sharing & running a domain of less than 10 users.
I have a twin Athlon MP box (1.67 GHz) do you think this is worth going with or is a newer P4 box going to deliver a lot more performance for not a lot of money ?
Thnaks
Martin
Thanks for the advice
Re Failure - usually have a 2nd system with identical set up that can be fired up if a major failure, use RAID + back up to NAS device for a restore. There would be some downtime but not excessive (hopefully !)
Re 2 boxes - could be a good plan hadn't thought of that due to management etc. but one could do PDC & file server & the other the SQL would also provide some failure protection as either could be temporarily pressed into action to do both roles.
Thanks
Martin
If you are looking for a cheap SMP box then the Pentium D 920 is pretty nice in my opinion, cheapest dual core x86 CPU you can buy (other than the out-going 820). Combined with a fairly basic 945G based motherboard and you will have a quick, very stable system.
I thought these new 9xx series cpus were only compatible with the 955 and 975 boards? Was looking at one on overclockers.co.uk and it says 955/975 only?
945G/P is definately dual core compatible wink.gif
Overclockers are wrong, the 945 chipset supports all 9xx series CPUs (EXCEPT] Extreme Editions, the 840EE and 955EE, these can only be used in 955 or 975 motherboards), I run a 950 in a 945G based Shuttle 169144-ok.gif
