jase1 Posted January 26, 2006 Report Share Posted January 26, 2006 Hi girlfriends dads S4 V8 makes a bloody awful noise on start up and has for some time, sounds like a bag of spanners for a second or so, even car judders as if engine is mis firing but once running is spot on, been into dealers today for first service and classic ( bearinf in mind it has made this noise every morning without fail) Couldnt hear anythiing sir, seems fine!!!!!!! any ideas?? Link to comment Share on other sites More sharing options...
Scotty Posted January 27, 2006 Report Share Posted January 27, 2006 A problems that exists only on cold mornings? You need to print this off and stick it under your dealers nose. I did and it was resolved without issue. HERE Link to comment Share on other sites More sharing options...
jdearauj Posted January 27, 2006 Report Share Posted January 27, 2006 [ QUOTE ] A problems that exists only on cold mornings? You need to print this off and stick it under your dealers nose. I did and it was resolved without issue. HERE [/ QUOTE ] Not to sure mine sounds like loads of spanners, but just sounds like the engine fan goes ballistic. It is also only on cold mornings. Does this fix maybe fix the issue I have? Link to comment Share on other sites More sharing options...
Scotty Posted January 27, 2006 Report Share Posted January 27, 2006 There's a couple of start up noises. The main one is the chain tightening. This takes a couple of seconds and it can be a little lumpy during that time. Not sure about the fan unless the noise sounds like a slipping belt in which case the TSB will help. Link to comment Share on other sites More sharing options...
Soapsuds Posted January 27, 2006 Report Share Posted January 27, 2006 i remember my old Golf GTi 8v many moons ago (Mk2) that used to click like crazy for about 5 seconds whilst the hydraulic lifers filled with oil!!! Very scary sound Link to comment Share on other sites More sharing options...
jdearauj Posted January 27, 2006 Report Share Posted January 27, 2006 [ QUOTE ] There's a couple of start up noises. The main one is the chain tightening. This takes a couple of seconds and it can be a little lumpy during that time. Not sure about the fan unless the noise sounds like a slipping belt in which case the TSB will help. [/ QUOTE ] The engine fan noise, it sounds more like the car has overheated and so the fan comes on to try cool it down. But is weird cos hear it when i start the car on a cold morning. Link to comment Share on other sites More sharing options...
umbongo Posted January 27, 2006 Report Share Posted January 27, 2006 Scotty - which noise does the bulletin resolve ? Mine whines loudly for a couple of mins on startup, goes away completely after that - figured it was just warming itself up. Booked in for a service at the end of the month so will push them for all updates. cheers Link to comment Share on other sites More sharing options...
Scotty Posted January 27, 2006 Report Share Posted January 27, 2006 Umbongo - it's the whine problem. It's very specific and only happens on cool/cold mornings. Link to comment Share on other sites More sharing options...
hashluck Posted January 27, 2006 Report Share Posted January 27, 2006 Ditto what Scotty says. Had the whine on mine and had them do the bulletin and all was well. Prior to that the dealer though it might be connected to another bulletin they had to do with the inlet manifold which they though a software update would cure. They did the update anyway but it was not that. Whatever, do not let them fob you off Link to comment Share on other sites More sharing options...
umbongo Posted January 27, 2006 Report Share Posted January 27, 2006 Thanks Scotty/Hashluck - called my dealer to add it to the actions on my upcoming service - they have gone away to think about it as they didn't recognise the bulletin when I read it to them and they are concerned that it might be a big job etc etc Basically if they can get the parts in advance I'm hoping it'll slip in with my existing service booking. Otherwise I'll be down there at the weekend with a print out to hand around. Do you remember if it took long for them to do it on your cars ? Link to comment Share on other sites More sharing options...
Scotty Posted January 27, 2006 Report Share Posted January 27, 2006 I think it is a big job. They probably don't recognise it as that TSB is from the US. I think my car was in overnight. Link to comment Share on other sites More sharing options...
lmmlmmam Posted January 27, 2006 Report Share Posted January 27, 2006 I have failed to get my dealer to do this mod. There's a slight problem as the TSB is not applicable to the engine code of most UK S4's. However the description is exactly like the problem Scotty and Hashluck have experienced and the TSB has fixed it for them. Haven't the time or energy to make a fuss to get it done. Link to comment Share on other sites More sharing options...
carlosshane1477 Posted August 13, 2011 Report Share Posted August 13, 2011 (edited) Hi girlfriends dads S4 V8 makes a bloody awful noise on start up and has for some time, sounds like a bag of spanners for a second or so, even car judders as if engine is mis firing but once running is spot on, been into dealers today for first service and classic ( bearinf in mind it has made this noise every morning without fail) Couldnt hear anythiing sir, seems fine!!!!!!! any ideas?? try checking the lifters.check your oil level, make sure it is at the top line.you have a clasped lifter does it quite down when it gets warm. Edited August 16, 2011 by shao_khan Someone forgot to read T&Cs Link to comment Share on other sites More sharing options...
rjgreen4 Posted August 15, 2011 Report Share Posted August 15, 2011 i have to admit when i start mine in the morning there is an initial burst and what feels like a crackle/rasp of the exhaust. Link to comment Share on other sites More sharing options...
