crasher Posted January 28, 2006 Report Share Posted January 28, 2006 Hi all Just run a full scan on my car with VAG-COM and here and some interesting snippets that i'd welcome input from the great wise ones on here... ------------------------------------------------------------------------------- Address 35: Centr. Locks Part No: 8L0 862 257 P Component: CV-Pump, Alarm, RC D17 Coding: 16236 Shop #: WSC 00590 7 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 00991 - Interior Lights 28-00 - Short to Plus ------------------------------------------------------------------------------- Address 03: ABS Brakes Part No: 4D0 907 389 E Component: ABS/ESP allrad D57 Coding: 08397 Shop #: WSC 02313 1 Fault Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 57: TV Tuner Part No: 4D0 919 146 C Component: TV Tuner H02 0430 Coding: 0000030 Shop #: WSC 00000 1 Fault Found: 01042 - Control Module; Not Coded 000 - - Any input greatly appreciated. The car is going into Audi on Tuesday for investigations into front brakes, so anything that i could get them to look at at the same time etc... Link to comment Share on other sites More sharing options...
Botang Posted January 29, 2006 Report Share Posted January 29, 2006 Your ABS/ESP fault has two possible reasons: 1) There is a brake in the CAN bus signal between the J104 Control Unitl (assume this is the ESP unit) and the Gearbox Control unit (known as the TCU). 2) The TCU has a fault code stored. You ought to get them to check the TCU for a fault. Link to comment Share on other sites More sharing options...
peterb Posted January 30, 2006 Report Share Posted January 30, 2006 The TV tuner fault is pretty well irrelevant - it means that the TV standard (UK PAL) has been selected from the H/U, but not coded into the tuner itself. As far as I'm aware, you can only do this with VAG-COM (or equivalent) - by positively setting the coding to 30. Link to comment Share on other sites More sharing options...
