[Audi A3/S3] 18" RS4 alloys fit on S3 or is lowering required?
s3geezer
Quick question - my S3 has the standard 17" Avus wheels but they are not in the best of condition.
It will cost me 200 GBP to get them refurbed at our local wheel shop or I have seen replica RS4 alloys on the internet with proper Audi centre caps. They look fantastic and I'd love to put them on my S3 but will I need to lower the car to make them look good or can i just bolt them on with profile 40 tyres and they would look good.
I don't want my S3 to look like it's on stilts! Does 1 inch make a difference to handling, looks etc is what I'm asking.
cheers guys.
How much is it advisable to get the car lowered onto the 18" inchers then (10/20 mm) and what make of springs are respectable. i am not a rude boy and I want to keep my sexy S3 as standard as possible but I can't resist those wheels and I want them to look as good as possible.
Paul - what is Quattro gmbh suspension?? Is that factory option or aftermarket accessory?
factory option, that the Audi UK eventually decided to drop from the options list for some reason.
It was still available from Germany till the end of production.
Its was sold as Quattro GmbH lowered and uprated suspension, and dropped the car approx 20mm
£280 should be about right. I paid £500 for fake ones with tyres, but they come with the chrome centres (bit naff). I'd avoid getting the wheel/tyre package as the tyres are utter crap. You'll be buying new tyres either way. I've dropped mine by 30mm with an Eibach Pro-Street S set-up. I could go lower but IMHO the slammed look isn't for me.
Unfortunately, that was a pic before I changed out the suspension. That's how it'll look with the standard set-up. Just too lazy to get some new pics up - should get around to it in the next few weeks.
If you do lower your S3, it can change the camber on the rear wheels to about -2°. It can make the wheels look like they've been sucked in, so spacers help a lot. Adjustable tie-bars would take out the camber, and save on tyre wear, but I like the handling just the way it is.
Whether you want to get your car lowered for cosmetic reasons or handling reasons is up to you but the latter will make a massive difference to the handling of the S3.
Personally i feel that the S3 standard suspension is too soft for a good handling car. You need to use a coilover setup if you can afford it or even just a good set of springs with matched dampers.
