DaveJ74 Posted January 29, 2006 Report Share Posted January 29, 2006 Hi everyone, just joined the site, looks great! I drive a 98 A4 2.4 SE and I have problems with the blowers, I tried to get some heat through yesterday, adjusted the climate control to suit but no heat! Not even cold air blowing out! My wife drives the car and it happened to her but later just came on, could this be an electrical fault with the climate control or a mechanical problem with the fan(s)? The car has been 100% relable over the past 2 years, and I was just chatting to a mate about the fact, just as this problem occurred - kiss of death eh?! Any help or advice would be greatly appreciated - given the current weather conditions! Cheers Dave Link to comment Share on other sites More sharing options...
UBM Posted January 29, 2006 Report Share Posted January 29, 2006 Dave. Welsome to TSN. It could be an electrical connection which is loose ot perhaps the fan is on its way out. Is the engine warm when it cuts out or is it on start up? Link to comment Share on other sites More sharing options...
DaveJ74 Posted January 29, 2006 Author Report Share Posted January 29, 2006 Hi,just popped out and started the car and the heater came on straight away - it did this yesterday but then cut off after 5 or so minutes of driving. Link to comment Share on other sites More sharing options...
UBM Posted January 29, 2006 Report Share Posted January 29, 2006 Could it be a thermostat problem? Is it not blowing hot air after 4 mins? Maybe its getting too hot and cannot control it? Either that or it is a loose connection which stops the fan when you go over a bump and comes back on again when you go over another bump? Have you got it set on Auto? Link to comment Share on other sites More sharing options...
DaveJ74 Posted January 29, 2006 Author Report Share Posted January 29, 2006 When it stops working, I've set it to Auto and tried it manually - even air-con, but nothing. I've started the car up and set the temp to 'Hi' and the air blowing out is getting warmer, so it's ok at the mo. I'll let it run till the engine gets hot and see if it cuts out then. Thanks for the advice :0) Link to comment Share on other sites More sharing options...
DaveJ74 Posted January 29, 2006 Author Report Share Posted January 29, 2006 Just popped out again to check and it's fine - blowing nice and warm in all directions! I've located the fan but it's a pig to get to, you have to remove the bottom windscreen cover, I'll check the electrical connections to it. Thanks a lot for your quick response, didn't expect a reply till much later :0) Link to comment Share on other sites More sharing options...
UBM Posted January 29, 2006 Report Share Posted January 29, 2006 Sometimes you just need to run the feckers on full for 5-10 mins to settle them down. Mine played up intermittently for a while and I blasted all the crap out! You might want to check your air filter too... Link to comment Share on other sites More sharing options...
DaveJ74 Posted January 29, 2006 Author Report Share Posted January 29, 2006 Will do, cheers! Dave J Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 29, 2006 Report Share Posted January 29, 2006 Probably a blower motor, about £250.00 plus fitting to replace, common issue on the B5 A4's. IIRC the part no is 8D2 820 021 Link to comment Share on other sites More sharing options...
DaveJ74 Posted January 31, 2006 Author Report Share Posted January 31, 2006 The blower has been playing up since, but yesterday I went over a huge pot-hole and it sprang back into life. It's still been playing up but when ever I go over a bump it often starts the blowers off! Maybe a loose connection somewhere - or like you say, a dodgy blower motor? :0( Cheers for the info Nelson. Link to comment Share on other sites More sharing options...
DaveJ74 Posted January 31, 2006 Author Report Share Posted January 31, 2006 Just found this on eBay - a much cheaper, brand new motor: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4609056279&fromMakeTrack=true Is it a 'DIY' job?! Dave J Link to comment Share on other sites More sharing options...
DaveJ74 Posted February 2, 2006 Author Report Share Posted February 2, 2006 Hi again, the fan is still intermitent, but now it's making some funny whining noises and doesn't sound very healthy, also it's not as powerful as normal (when it was working ok!) Best start looking for a blower motor......www.ebay.co.uk me thinks....... Link to comment Share on other sites More sharing options...
DaveJ74 Posted February 13, 2006 Author Report Share Posted February 13, 2006 Managed to remove the fan motor and get some oil on the spindle - works fine now! 3 hours of cutting my arms up and rather blue language and I've saved myself a couple of hundred quid! DaveJ Link to comment Share on other sites More sharing options...
Nelson_R32 Posted February 13, 2006 Report Share Posted February 13, 2006 God I'm good JK, glad you got it sorted Link to comment Share on other sites More sharing options...
DaveJ74 Posted March 6, 2006 Author Report Share Posted March 6, 2006 Well the motor's seized a couple of times since then so I'm just removing it and oiling it when ever it stops - a pain, especially in this cold weather! Im gonna give in and get hold of another - seen them on ebay for £100 approx, but I'm sure there must be an A4 breaking somewhere...... Link to comment Share on other sites More sharing options...
