Phatnoise and now for the next problem?
You need a Phatnoise (VW) interface lead part # 000 051 592
Unfortunately you have got
Phatnoise (Audi) interface lead part # 000 051 592A
You can buy Phatnoise (VW) interface lead from www.clairparts.com $ 45.35 or do a search on Google might be cheaper somewhere else.
or
Modify the existing Phatnoise Audi cable to fit using the pin outs on www.phathack.com (requires cutting of cable) .
I have the same and you have to remove the tasty alloy casing, undo all the screws except the one on the back then you need a thin object to slide under the bottom of the plastic face plate and gently lever it up there's two catches once these release it lifts quite easily.
There are two more screws under there once these are undone the casing comes off, I'm going to make a faceplate to box the Phatbox in as I think it'll be a bit unsightly with it's innards showing.
I would like to know what Audi doin this situation?
I thought about making a faceplate but didn't for two reasons.
[1] I don't have my head in the glovebox that often and it's dark all around it so it doesn't really notice.
[2] It's inside the fecking glovebox!
Looks like I will have to go for the rear mounted option, found fab install notes here:
http://www.audiworld.com/tech/elec127.shtml
This website is USA but is very very big.
Glovebox installation found here:
http://prw.prehiti.net/s42k5phatbox/
another here:
http://members.cox.net/rcflier/Library/WebServer/Documents/pictures/phatbox/index.html
Cheers
Peter
The aluminium frame/heatsink is much smaller on the Phatbox shown............. ?
I imagine the heatsinks have been trimmed - down.
I can't believe either of those installs - they have done some of teh work so neatly but other parts just seem illogical !
Best one I remember seeing was the enitre unit transplanted into what was basically an ice cream tub held together with cable ties !
