EPC Warning
allanon_1980
Send it into get checked by the dealer. Does the ABS light also come on? If so an ABS sensor may have fallen off. Jack your car up and have a look around, it's just a lead that goes into the pad (not the fluid cable, don't touch that!). Please remember to use axel stands wink.gif
I'm assuming that EPC is the traction/stability control?
If you're saying the light stays on permanently once you start up then I would take it to the dealer straight away to be checked out.
It will as you probably know stay on for a few seconds during ignition switch on as part of lamp function test.
I think EPC is part of the engine management system, emissions etc.
