Removing boot hatch upholstery
torqtoise
Anyone know how to remove the black upholstery/trim off the interior rear boot door,
ive got screen wash pouring into the boot , the hose seems to have some disconnected from the rear wiper behind the trim,
ive removed the 2 black screws from the 2 recessed handles (which you use to close the hatch) but it still seems really stiff and i dont want to snap anything
i had the same problem 2 nights ago. the alarm was also going off as the water had indeed penetrated the switch, like the write up says you do need to prise the lower panel once you have released the 2 screws, take care not to break anything, but with a good tug blush.gif you should be able to get the panel off. luckily mine was not damaged and had simply unclipped although i did have a new rear screen a few months ago so they might not have reattached it properely at the time. 169144-ok.gif
