Zenyck100 Posted February 1, 2006 Report Share Posted February 1, 2006 light has stayed on so i got home and hooked up my vag-com lead and this is what i got: Wednesday,01,February,2006,18:04:26 VAG-COM Version: Release 512.1-UD Chassis Type: 1J - VW G/J/B Mk4 Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 76 VIN Number: ------------------------------------------------------------------------------- Address 01: Engine Part No: 022 906 032 CP Component: MOTRONIC ME7.1.1 0001 Coding: 0000132 Shop #: WSC 78388 1 Fault Found: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal P0116 - 008 - Implausible Signal Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Part No: 1C0 907 379 P Component: ESP ALLRAD MK60 0101 Coding: 0023049 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Part No: 3B1 907 044 C Component: CLIMATRONIC C 2.0.0 Coding: 11000 Shop #: WSC 31414 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 37-10 - Faulty - Intermittent ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 17: Instruments Part No: 1J0 920 926 J Component: KOMBI+WEGFAHRSP VDO V20 Coding: 05410 Shop #: WSC 00000 WVWZZZ1JZ3D673052 VWZ7Z0C7883322 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Part No: 02D 900 554 C Component: HALDEX LSC ECC 0010 No fault code found. ------------------------------------------------------------------------------- Address 29: Left Light Part No: 7M3 907 391 Component: EVG GDL + AutoLWR 0003 Coding: 00002 Shop #: WSC 00001 No fault code found. ------------------------------------------------------------------------------- Address 39: Right Light Part No: 7M3 907 391 Component: EVG GDL + AutoLWR 0003 Coding: 00002 Shop #: WSC 00001 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Part No: 1C0 959 799 B Component: BZ Komfortgerát HLO 0003 Coding: 00064 Shop #: WSC 31414 Part No: 1C2959802A Component: BZ Tõrsteuer.FS KLO 0202 Part No: 1C2959801A Component: BZ Tõrsteuer.BF KLO 0202 1 Fault Found: 01135 - Interior Monitoring Sensors 36-00 - Open Circuit ------------------------------------------------------------------------------- Address 56: Radio Part No: 1J0 035 186 D Component: RADIO SON 0004 Coding: 01403 Shop #: WSC 31414 No fault code found. The End -------------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------------------- the engine coolant temp sensor has been showing a fault for a while but with no engine management light. Any ideas anyone????? Link to comment Share on other sites More sharing options...
Decked Posted February 1, 2006 Report Share Posted February 1, 2006 Have you got the Revo Stage 2 code? If your running Stage 1 have it upgraded. You should be able to get the upgrade for around £50. This will eliminate this fault code I think, I've spoken to Revo about this and so far it's worked on mine. Something to co with lamba probes conflicting Link to comment Share on other sites More sharing options...
Zenyck100 Posted February 1, 2006 Author Report Share Posted February 1, 2006 I have booked in for the stage 2 along with 2 new tyres hopefully this week. Have you had the stage 2 yet?? Link to comment Share on other sites More sharing options...
jimmyp Posted February 2, 2006 Report Share Posted February 2, 2006 I have had an update for the Revo software, and it's supposed to improve the fuelling, ignition, torque etc etc. I'm running the car on stock mode at the mo but looking forward to switching back to performance to see if it's an improvement. Link to comment Share on other sites More sharing options...
Zenyck100 Posted February 2, 2006 Author Report Share Posted February 2, 2006 False alarm guys, its my emissions light that is on Anyone know the cause??? Link to comment Share on other sites More sharing options...
Decked Posted February 2, 2006 Report Share Posted February 2, 2006 Yeap got stage 2 now and i though the emmisions light was the same as the engine management, the one below the traction light..... Link to comment Share on other sites More sharing options...
Zenyck100 Posted February 2, 2006 Author Report Share Posted February 2, 2006 I was reading the manual and is states the "EPC" is the engine management light. Link to comment Share on other sites More sharing options...
BigMeanBob Posted February 2, 2006 Report Share Posted February 2, 2006 What exhaust you got on Zenyk? b0b Link to comment Share on other sites More sharing options...
Zenyck100 Posted February 2, 2006 Author Report Share Posted February 2, 2006 i have a milltek m8 Link to comment Share on other sites More sharing options...
Rocket_Man Posted February 2, 2006 Report Share Posted February 2, 2006 [ QUOTE ] 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal [/ QUOTE ] I did a quick Google and found someone on AudiWorld saying they had the same issue. Changing the coolant temp sensor fixed the issue. Then you can wait for the light to come back on because of the exhaust (thats an easy fix cos i just did mine) Link to comment Share on other sites More sharing options...
Zenyck100 Posted February 2, 2006 Author Report Share Posted February 2, 2006 Easy fix?? What was your fix for the exhaust?? Link to comment Share on other sites More sharing options...
Rocket_Man Posted February 2, 2006 Report Share Posted February 2, 2006 [ QUOTE ] Easy fix?? What was your fix for the exhaust?? [/ QUOTE ] Firstly the problem is a common one with cars which have aftermarket exhausts fitted. The error code in VAG-COM is this: 19473 - Valve for Exhaust Flap 1 (N321): Short to Plus P3017 - 001 - Upper Limit Exceeded If you lift the carpet and foam "thing" out your boot you will see two groups of wires. In the group of wires on the right there is a blue-grey wire that goes to the infamous flapper pump. If you cut the tape back that holds the wires together (without cutting wires) you will find it. You then need to cut the blue grey wire (there's only one) and insert a 1-2kohm resister and tape the whole lot back together. Once this is done, you need to reset the error code using VAG-COM (or remove the battery) and the error won’t come back. I had the light on for nearly 4 months before doing this (drove me mad!) Link to comment Share on other sites More sharing options...
jimmyp Posted February 3, 2006 Report Share Posted February 3, 2006 [ QUOTE ] False alarm guys, its my emissions light that is on [/ QUOTE ] I had the emissions light flash up and it was due to a coil pack misfiring, and if it stays on, it means (i think) that the cat is on it's way out. I hope you get it sorted mate. Link to comment Share on other sites More sharing options...
