Zenyck100 Posted February 1, 2006 Report Share Posted February 1, 2006 light has stayed on so i got home and hooked up my vag-com lead and this is what i got: Wednesday,01,February,2006,18:04:26 VAG-COM Version: Release 512.1-UD Chassis Type: 1J - VW G/J/B Mk4 Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 76 VIN Number: ------------------------------------------------------------------------------- Address 01: Engine Part No: 022 906 032 CP Component: MOTRONIC ME7.1.1 0001 Coding: 0000132 Shop #: WSC 78388 1 Fault Found: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal P0116 - 008 - Implausible Signal Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Part No: 1C0 907 379 P Component: ESP ALLRAD MK60 0101 Coding: 0023049 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Part No: 3B1 907 044 C Component: CLIMATRONIC C 2.0.0 Coding: 11000 Shop #: WSC 31414 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 37-10 - Faulty - Intermittent ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 17: Instruments Part No: 1J0 920 926 J Component: KOMBI+WEGFAHRSP VDO V20 Coding: 05410 Shop #: WSC 00000 WVWZZZ1JZ3D673052 VWZ7Z0C7883322 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Part No: 02D 900 554 C Component: HALDEX LSC ECC 0010 No fault code found. ------------------------------------------------------------------------------- Address 29: Left Light Part No: 7M3 907 391 Component: EVG GDL + AutoLWR 0003 Coding: 00002 Shop #: WSC 00001 No fault code found. ------------------------------------------------------------------------------- Address 39: Right Light Part No: 7M3 907 391 Component: EVG GDL + AutoLWR 0003 Coding: 00002 Shop #: WSC 00001 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Part No: 1C0 959 799 B Component: BZ Komfortgerát HLO 0003 Coding: 00064 Shop #: WSC 31414 Part No: 1C2959802A Component: BZ Tõrsteuer.FS KLO 0202 Part No: 1C2959801A Component: BZ Tõrsteuer.BF KLO 0202 1 Fault Found: 01135 - Interior Monitoring Sensors 36-00 - Open Circuit ------------------------------------------------------------------------------- Address 56: Radio Part No: 1J0 035 186 D Component: RADIO SON 0004 Coding: 01403 Shop #: WSC 31414 No fault code found. The End -------------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------------------- the engine coolant temp sensor has been showing a fault for a while but with no engine management light. Any ideas anyone????? Link to comment Share on other sites More sharing options...
