Parking sensor beep
sapphire1616
I have exactly the same problem with my S8 - initially they worked intermittently then stopped alltogether with the beep you describe (as detailed in handbook!). I had guessed that my problem is one of the front sensors because one has been hit by a stone (or something similar) and had been displaced. Sure enough, when I checked with VAGCOM it confirmed "front center right sensor faulty" exactly the one I suspected. I have not got round to replacing it yet because you need to take the bumper off to reach the back of the sensor. Incidentally, does anyone know if I can disable the front sensors in VAGCOM so that the back ones work?
