harddrive Posted February 3, 2006 Report Share Posted February 3, 2006 I got a VAG-COM cable today and tried to recode the car for the RNS-E I followed the instructions and went to the following channel but it comes up with an error saying it can not read the channel 62 STG 17 (Instrument cluster) -> Adaptation -> Function 10 -> Channel 62 I currently have a cable going between the RNS-E and the instrument cluster that I had to connect when I installed the sat nav. Does anyone know why I get this error and/if the cable is the cause?? Link to comment Share on other sites More sharing options...
PetrolDave Posted February 3, 2006 Report Share Posted February 3, 2006 What version of VAG-COM are you using? You need to use version 4.01 or later - earlier versions didn't support the higher numbered adaptation channels. Link to comment Share on other sites More sharing options...
harddrive Posted February 4, 2006 Author Report Share Posted February 4, 2006 Im using latest version off the ross-tech site, I think the number is 5.12 Link to comment Share on other sites More sharing options...
PetrolDave Posted February 6, 2006 Report Share Posted February 6, 2006 Just been reading on http://www.navplus.us. On the A3 you need to change the settings on your CAN Gateway, not on the instruments, to enable navigation on the DIS. Try using the long coding helper (built-in to 5.12-1) to see what settings need to be changed. Link to comment Share on other sites More sharing options...
harddrive Posted February 6, 2006 Author Report Share Posted February 6, 2006 Thanks this has solved the problem and I have enabled the car for NAV! Link to comment Share on other sites More sharing options...
