Oatz Posted February 6, 2006 Report Share Posted February 6, 2006 please see here http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/1,2,12,15,22,25,26,27,8/Number/702153/an/0/page/0#702153 Many many thanks Link to comment Share on other sites More sharing options...
N3WOB Posted February 6, 2006 Report Share Posted February 6, 2006 Doesn't work Link to comment Share on other sites More sharing options...
Oatz Posted February 6, 2006 Author Report Share Posted February 6, 2006 Ooops I'll just post it instead; Calling all dension/ipod con. and MKIV Golf owners Please help! If you have mounted yours in the glovebox how did you get the lead in there in the first place? I'm trying find a way of getting the connector into the glove box and heard there maybe a hole somewhere already but i can't find it...? Cheers in advance Link to comment Share on other sites More sharing options...
mb Posted February 6, 2006 Report Share Posted February 6, 2006 Don't have an iPod but have taken the gb out - didn't notice any holes (apart from light). I think if I were doing it I would drill a hole in the corner of the gb - make it a size you can buy grommets for & you can always cover it up later - if it is in a corner no-one will ever see - or run it through the light as it is less useful than an iPod. Link to comment Share on other sites More sharing options...
Mook Posted February 7, 2006 Report Share Posted February 7, 2006 I drilled a very small hole in the top of the inside of the glovebox to route the cable from the Dension mount to the strip of elecronic widgets, which is stuffed up behind the glove box. Link to comment Share on other sites More sharing options...
Oatz Posted February 7, 2006 Author Report Share Posted February 7, 2006 Cool thanks for the replies, in that case think i might just drill a small hole next to the glovebox light (just big enough to feed the cable through Link to comment Share on other sites More sharing options...
Oatz Posted August 27, 2006 Author Report Share Posted August 27, 2006 Bit of a blast from the past but I have just discovered that there is a hole in the very top of the glovebox so for the archives, you DO NOT need to drill the glovebox Link to comment Share on other sites More sharing options...
