NunchukHamster Posted February 7, 2006 Report Share Posted February 7, 2006 2000 Passat 1.8T Sport Estate, the rear wipe is fine, but the washer jet is u/s. I've cleared the nozzle, checked the water bottle is full, and there doesn't seem to be a "mysterious" wet patch in the boot from a leak at that end. I can here the pump so it's not the stalk control gone, and the front jets work so I guess the pump is ok. Anywhere else that is a common blockage/dis-connection point? Starting to get very bored of cleaning the window by hand every other day! Link to comment Share on other sites More sharing options...
meriafel Posted February 7, 2006 Report Share Posted February 7, 2006 Just a quick reply to show someone is listening! Isn't the washer pipe connector that comes adrift in one of the estate rear storage pockets and not in the 'boot'? Was once told that if you try and operate the rear washer when the rear nozzle is frozen you will blow this water-feed pipe joint. Check it out. Is the washer motor running when you operate the rear washer? Am sure Mulkbear and others will know the answer. Link to comment Share on other sites More sharing options...
NunchukHamster Posted February 8, 2006 Author Report Share Posted February 8, 2006 Yeah the motor is running, will go and investigate storage pocket. Cheers. Link to comment Share on other sites More sharing options...
v23 Posted February 8, 2006 Report Share Posted February 8, 2006 Yeah, mine stopped working shortly after I bought the car. The hose had come undone inside the CD changer cubby and was squirting water all over it. Link to comment Share on other sites More sharing options...
NunchukHamster Posted February 9, 2006 Author Report Share Posted February 9, 2006 Seems to be dry in the cd changer storage. Any other offers? Link to comment Share on other sites More sharing options...
meriafel Posted February 10, 2006 Report Share Posted February 10, 2006 Can't helf further other than to add that mine was fixed under warranty and the water was in the jack/wheel brace space but most had disappeared beneath this plastic moulding. Make sure you have had a really good look as I was not aware of the problem as it was found at a service. Link to comment Share on other sites More sharing options...
NunchukHamster Posted February 11, 2006 Author Report Share Posted February 11, 2006 Cheers meriafel, will go looking again after work. Link to comment Share on other sites More sharing options...
