ChaiHal Posted April 18, 2006 Report Share Posted April 18, 2006 I’ve just realised that my front fogs are on when my headlights are also on. I don't seem to be able to switch them off. The headlight switch has a position for both rear and front fogs, but at the moment it only appears to control the rear fogs. I'm pretty sure that this is something new, I've had the car since December and I seem to remember checking in the past they were working correctly. Before I dive in to find the problem, anyone have any ideas where I should start? My logic dictates starting with the switch, but hey what do I know? Quote Link to comment Share on other sites More sharing options...
shark_90 Posted April 18, 2006 Report Share Posted April 18, 2006 The legend of hardwired fogs! It could possibly be the switch, but as you say, it's controlling the rear lights correctly. I'd probably still start there by replacing the switch, and then delving further. Do they come on with your sidelights, or only when dipped beam is on? Quote Link to comment Share on other sites More sharing options...
ChaiHal Posted April 18, 2006 Author Report Share Posted April 18, 2006 OK, freshly back from the car park. Front frogs are on with side ligts, dipped lights and main beam. Basically the front fogs are off only when the other lights are off. Quote Link to comment Share on other sites More sharing options...
shark_90 Posted April 18, 2006 Report Share Posted April 18, 2006 I had a thought, but I've confirmed it's not that.. try the switch first, failing that it'd need some serious investigation, particularly as you say it's something that's happened recently/since you've had it. Quote Link to comment Share on other sites More sharing options...
ChaiHal Posted April 22, 2006 Author Report Share Posted April 22, 2006 Managed to get the switch out today, but couldn't get it out far enough to disconnect the cables at the back of it. So I just put it back in and now the fogs function correctly. Looks like I may have a dodgy switch, but as it's working OK at the moment I'll leave it alone. Quote Link to comment Share on other sites More sharing options...
CarMad Posted April 23, 2006 Report Share Posted April 23, 2006 They are set to BMW mode... thats your problem. Quote Link to comment Share on other sites More sharing options...
ChaiHal Posted April 23, 2006 Author Report Share Posted April 23, 2006 Thought I'd been feeling wierd recently. I'll speak with the Dr on Monday, see if I can get a personality Quote Link to comment Share on other sites More sharing options...
fingermouse Posted April 24, 2006 Report Share Posted April 24, 2006 been thinking about swapping the wires on mine so the rears come on first. Quote Link to comment Share on other sites More sharing options...
Mo-S3 Posted April 24, 2006 Report Share Posted April 24, 2006 [ QUOTE ] been thinking about swapping the wires on mine so the rears come on first. [/ QUOTE ] The current set up with the fronts on first and rears on second is pants IMHO. I prefer to be able to flick the rear fogs on second to warn tailgaters to back off a bit instead of having to flash the oncoming drivers with my PIAA fogs. Quote Link to comment Share on other sites More sharing options...
