Lowering B6 A4 Avant
AvantSE
keep trying to find the time to do mine! It's relativley simple, especially at the rear as you dont need to remove any components apart from the spring itself!
Spring kits vary. Awesome-GTi had Koni's on offer recently for your motor at about £75inc. VAT. Cheapest good spring around. PI and GMax etc. are about 100-120 quid. 169144-ok.gif
Get yourself a copy of ElsaWin and ETKA and you get al the exploded diagrams you could ever need and also a walk-through of how to fit. HTH!! 169144-ok.gif
Been doing a bit of research, but I am wondering about fitting the springs on their own... I know it won't be as good as with matched dampers, my main concern is that std dampers with short springs may cause them to drop out of the spring platforms.
Roughly what would be the fitting cost of a full suspension kit (springs and dampers?). The rears look simple, the fronts look a bit of a nightmare.
Fitting shortened springs to standard dampers won't cause any major problems (unless the springs are really short). You will probably find it will shorten the life of the standard dampers. Ideally you should go for matched dampers and springs.
Ta, think I am going to go for a cheap kit such as GMax or similar, can't really stretch to Konis etc.
I used these springs when lowering my B6 saloon. Paid £120 for fitting.
h**p://www.motechdirect.co.uk/motechdirect/content.asp?cat=1140PK&catalog=114002PK&inc=eibach
Anyone ?
Anyone ?
eBay - of course, this would be to purchase a copy of the CD's for the genuine licence you already have at home. Purely for back-up reasons as you dont have, nor can get to, a CD-burner....... sekret.gifsekret.gif
