[Audi A3/S3] Changing headlights & rear lights
audisport
bit of work unfortunately, you need to remove a small amount of the wing on the inside, you also need to remove the whole front bumper assembly if i remember rightly, could be done in a morning at the weekend, its more down to your confidence at cutting the wing crazy.gif
if i remember correctly theres a guide on another site about it, might be worth doing a quick search through the older posts in this forum for the link 169144-ok.gif
*waiting for Paul-S3 to correct me laugh.gif*
Rear lights i believe are a straight swap.
Front lights not so. Just as sufu mentions, a small fag packet sized piece of the inner wing has to be cut out.
To get the headlights in/out, its a bumper off job.
