rear door card removal a4 avant
a4alan
Just gained a dent free of charge from some tw.t on my rear driver side door on my beloved a4 avant 2004..As per normal nobody owned up!!, How easy is it to remove the card without the future rattles when the poppers fail..to gain access for chips away to try and repair..any thoughts, and has anyone used chips away in the carlisle area.. frown.gif
Not done it but hopefully this helps :
- Door trim.
Removal
- Unclip decorative panel -2-.
- Remove decorative panel -2- toward front.
- Remove bolts -3- (3x) from door trim -1-.
For vehicles with electric window regulators
- Window regulator switch, removing and installing Page 70-25 .
For vehicles with manual window crank
- Manual window crank, removing and installing Page 70-26 .
For all vehicles
- Unclip door trim -1-. Replace damaged clips Fig. 3
- Raise door trim -1- upward approx. 20 cm. out from door shell.
- Disengage Bowden cable for interior door mechanism Fig. 1 .
- Disconnect electrical harness connectors Fig. 2
I have sympathy for you, especially since last weekend, some tw.t also put a dent in my front passenger door!
It was done in a carpark in the Lake District (near Coniston). Funny enough, whilst we were walking back to our cars, some careless willyheads had their door open fully, resting against my mates car. He looked at his car after they closed the door and there was a dint and some scratching... and the cheeky buggers denied it was them, despite the fact we saw everything!
I'd be curious to know how you get on trying to remove it. Is it a large dent or small one? Is it possible to post a picture?
Hope it works out for you.
No it`s small but on the flat panel bit so seen easily from side view, i also have one on the bonnet front that the wonderfull tyre fitters did at Gates tyres, cant prove it was them but it wasn`t there prior to them fitting my new fronts, that one will be a bitch as it`s behind the double skin..i`ll take photos monday if the lord decides to stop raining..cheers
shocked.gif What came of it? Did they drive away?
  • 2 weeks later...
Sorry didn`t manage to get photos as the man from Dentco Ltd arrived to repair my dents, He is based in Whitehaven Cumbria, i had one on the driver side rear, one on the bonnet and one on the passenger side rear panel and 2 hours later all gone...what a brill job he made, cant see any of them at all...SUPERB...and the cost £70 CASH..WHAT A MAN 169144-ok.gif169144-ok.gifjump.gif123576-assfeck.gif, well recomeded..
Guest
Reply to this topic...
  Only 75 emoji are allowed.
