what fuel?
Maxyboy
i have heard that the fsi engines really benefit from optimax...but as the r32 is not fsi...and as far as i can make out...and the fuel management adjusts the car accordingly as per type of fuel put in....is it any advantage to rum optimax over normal unleaded? slap.gif
The recommended fuel for the R32 is 98 octane and Optimax is the only fuel that meets this spec, except for Tesco 99.
Yes, you can argue that the ECU will adapt to the fuel that's in the car, but Optimax definitely makes my car run more smoothly and with more mpg.
HTH
Get a job where the company picks up the fuel bill. Job sorted! :?)
[/ QUOTE ] well....i've got a job where the company picks up the fuel bill......in this case though its unfortunate that the company is mine.....looks like optmax then..... 123576-assfeck.gif
I worked out, when I had my R32, that I'd save about £45-£55 pa if I ran it on regular unleaded... better MPGs v's lower cost balanced out in favour of cost to the numbers mentioned.
Not really worth it.......... R32s and pondering over fuel consumption, costs, savings, should not be considered at the same time - ever!
The recommended fuel for the R32 is 98 octane and Optimax is the only fuel that meets this spec, except for...
Not down here. 95 RON is what is written on the fuel filler flap.
