[Audi A3/S3] Strange Noise on Suspension
bpsmith
I seem to have a small noise coming from the front of my A3 1.8T. It seems to make a creaking noise when the body or suspension is twisting and only happens when almost stopped? It is very difficult to describe but I wonder if anyone else has noticed this?
The car is still under its 12 month warranty as bought it from dealer 2nd hand so may well take it to them to look at although it is difficult to do this due to the creak not always being able to be replicated on tap, so to speak.
pretty sure I know what this is
had same problem on my 23k mile S3 and ex girl friends 44k mile TT.
Its probably the front anti roll bar bushes. Does it sound like a creaking noise ?
They also replace the anti roll bar because the worn bushes damage the roll bar.
I got a 70% contributiom from Audi cos it was out of warranty (import).
Watch the price though, if I'd paid full price it would have been about £160, but ex was quoted over £300 at another dealer. Jury is out though whether you need the alignment done afterwards. The front wishbones have to be dropped to do the job. Mine wasn't done, but the other dealer said it needed it. I queried my dealer but they were adamant it didn't need it. Instills confidence when dealers disagree!
Cool. I will get this checked with a mate at ATS first and can see for myself if this is likely to be the problem. I can then tell them straight at the dealer. Would this be an item that is covered by the 12 month 2nd hand car warranty though? If so I will get them to change them and hopefully do the alignment too under the warranty!?!
  • 2 weeks later...
I just went to ATS to see if my mate was there as not seen him for a few months now.
We was not there as, back in June, he was racing one of those really "mini" motorbikes around the local race track (Pembrey) and one of the bolts on the front caliper sheered off and hit his knee and ankle and he came off the bike. He wont be back in work for the rest of the year!!!
Anyway, I had the exhaust checked out as a lot of warm air was coming from under the driver side door when I stopped and got out of the car and I wanted this checked. It turns out to be the heat generated from the CAT. I took the liberty of getting the front end looked at around the roll bar and bushes and all are fine. They have sprayed them with WD40 to try this as weather has been very dry and early impressions seem to be that this has fixed the problems with the squeak! Thanks for the pointer and hopefully it will stay right for a while now. The car is booked in next week for the other issue with the vibration and revs pausing at 1.2K after coming to a stop to be looked at so I will ask them to check this out too. Although I know they will probably tell me that it is fine and not even check it knowing them at my local dealer!?!
I have been driving the car for a few days now, since the bushes were sprayed and the noise is back! Cant tell where it is coming from still but know that the guys in ATS checked them all out visually and they were all fine. I had a glance myself and could not see anything amiss, so dont hold my breath when the local dealer has a look at it due to the fact that it is a little bit intermittent and that they tend to palm people off in saying nowt is wrong.
My A3 has been creaking badly for the past few weeks, the noise seems to come from somewhere under the clutch pedal if I had to pick a location. Went into my dealer three times before they eventually found it and replaced
2x rubber mounts (1J0411314T) @ 3.63 +VAT
1x Stabiliser (8N0411303G) @ 47.00 +VAT
All back to normal now ... hope this helps.
Mine seems to be when I twist the car and also when I am almost at stand still and again when I brake fairly heavy at almost stand still.
These could all point at dodgy engine mounts I suppose so will have a look at that too. Would I see this visually when I jack the car up or put it on ramps?
I had exactly the same problem... a good test is speed bumps, when you come down the speed bump the suspension creaks...
Had to have my front anti-roll bar replaced along with the bushes and this sorted the problem straight away. Was all covered under the warranty and when I had a quick look at the warranty receipt it was quoted at £338 (Lucky I didn't have to pay!)
As soon as I took it into the Audi dealer they knew exactly what it was... apparently pretty common.
I've had the same thing replaced a couple of months back... been sweet as since. Didnt realise it costs that much tho, thank feck for warranty the_finger.gif
I managed to relpicate it by pushing down and back (Towards the rear of the car) on the front wing... bouncing it a fair bit seemed to start the creak off... made a difference of I had a passanger in the car too... I am surprised by your dealer not being able to replicate it... my dealer is Sh*t hot when it comes to that sort of stuff... As soon as I described it they knew exactly what it was... Same with my steering column fault as soon as I described my problem they gave me 3 possible causes and they were spot on...
Thanks, I will try doing that tomorrow after work and see if I can hear it.
What problem did you have with the steering column also as seem to have a strange noise from that when moving from left to right passing over the centre. It is quite notchy but that may well be standard thing as there may be a groove of some sort?
Funny you should say that as that is the problem that I had... When you move the wheel over centre it would feel rough and almost step down slightly, almost like a minor knock... This was due to a worn bush (Again) on my steering column and had to have the whole column replaced... nasty thing was it came back again on the second column fitted so had to have another... plus some additional parts that I think should have been fitted anyway...
The roughness sometimes turned into a knock, especially if the steering lock had been applied hard... and seemed to reduce when the car was warm or if the wheel was moved a fair but. All covered under warranty so I didn't have to pay... don't fancy the cost of a new steering column...
If I were you I would have the car properly checked out by a dealer you can trust...
Hmmm...I think my local dealer is pulling a swift one by the look of it!?!
Thing is, the 3 nearest dealers are all owned by the same people. I wonder where else I could get it looked over by?
Would they then charge for this or is the warranty the same no matter which dealer you go to considering I bought the car second hand?
Is there any other tell tale signs for me to look out for.
Thinking about it the creak from the front could be down to the same thing as I thought it was when the suspension was at full torsion when turning but could just be the steering making the noise and not being obvious.
I have a shake from the wheel at around 80mph too and thought that was down to balancing which I have been meaning to get looked at. All the signs seem to be there?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
