Oil drip onto exhaust
sapphire1616
I have noticed an oil drip onto the exhaust, just roughly where the gear lever is positioned. It's a 2002 S8. Any common oil leak problems on this model? I only just noticed it after not using the car for about 10 days. It burns off but am a bit worried incase its transmission fluid as I don't see a way to check the level. Any guidance most appreciated.
Its a common fault with all V8 tipronics A6 & A8, have a look at the guide on Audipages
I understand that they have recently superceeded the part but this has been a known issue for a long time.
Not sure about the fire risk mine has done it for years without any problem.
Its a tiny amount of fluid that drips onto the left cat IIRC.
Thanks very much for the info. Really appreciated. I am paranoid about my S8 so you have been a great help. Guess its a trip to the stealers now. Any idea of how much money I can expect to be taken for?
It's a very simple job, the seal is £10 it took my mechanic a couple of hours but most of that was freeing siezed bolts on the exhaust, cost me about £60.
If you know a mechanic you trust to do the work I wouldn't go to audi with this
Cor Botang. I have just seen your exhausts. Where do I get them for mine. They are wicked!
Mine came from a company called EPS in Holland, although a few members have a similar system made by LPS in Ipswich. Have a sear for quad exhaust and youll find all you need to know.
Looks like I was wrong on the superceeded part, I was thinking back to an Audiworld post that I had read but unfortunately that was for a clutch seal.
They say around $350 for the repair, so I think Charlie had a bit of a result with £60.
As others have already said, this is a very common problem; usually occurs betweenabout 40k to 90k miles. Almost all cars seem to be affected eventually. I had mine done at the stealers; oil (for top up) and new seal less than £15 but about 2 hours labour so total bill about £250 including vat.
Replacing an oil seal is one of the easiest jobs on a car, this one is better than most because it's easy to get at, you just take the exhaust off and you can get at the driveshaft, mine was the offside one.
I really don't see the need to pay £120 an hour for such a simple job unless it's under warranty in which case it will cost you nothing.
find someone competent and save £150 on the labour rate
Guest
Reply to this topic...
  Only 75 emoji are allowed.
