audi newbie needs help
tonymontana
hi folks. just converted to the audi world from the dreaded french side. i have just purchased a 95 a6 2.0e. not magnificent but we all gotta start somewhere. heres the thing. seems to be an intermittent immobiliser problem. sometimes it starts and sometimes it dont. took it to a vw garage and he said it was the coil reader round the ignition barrel. changed it, didnt help. once again the car has let me down and ive had to take a day off work. is there any way to bypass the immobiliser? dont really want to replace the igniton barrel and key etc. lookin for a cheap way out. any help would be greatly appreciated. great site by the way.
yeah. tried both keys. dosent seem to make a differnce. had the car on vagcom and it says 00128 immobiliser speradic fault and 00176 key speradic fault. does this mean i replace them both or do i replace the key? also comes up 00522 coolant temperature sender implausible signal speradic fault. would this stop it from starting also?
  • 3 weeks later...
The coolant sensor is the one with a multi connector on it. I cannot tell you where it located because I only know the V6's not the 4's. It is either a screw-in type with a black top or a push in type with a green or black top I think. If it is the push-in type it will be helpd in with a plastic horseshoe type clip - get a new one of these as well because it will break as it is removed.
For the imobiliser, I would get a new induction loop for the lock bareel. This must have developed a fault if it the same with both keys. It maybe possible to re-programme the keys - do a search on www.audiworld.com on the C4 A6 forum. They only had immobilisers in the US from about 96 on but there will be loads of info.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
