nordberg Posted August 1, 2006 Report Share Posted August 1, 2006 I'm guessing it's impossible to have just the fan on without the a/c? Today, for instance, I'd love to be able to just have the air moving inside my car without having to set a temperature. Quote Link to comment Share on other sites More sharing options...
Paul Posted August 1, 2006 Report Share Posted August 1, 2006 sorry not familiar with the A4 climate control units Have you got an "ECON" button? if so that turns off the a/c Quote Link to comment Share on other sites More sharing options...
Milo Posted August 1, 2006 Report Share Posted August 1, 2006 Bit confused You can turn the aircon off just by pressing the econ button. This just makes the heating/ventilation system the same as a car without aircon. You still need to set a temperature though, the same way you would in a car without aircon - on yours you set it exactly rather than using a rotary dial. You can then set your fan speed manually as well, the same as you would on a car without aircon. I tend to leave mine between LO and 18°C, usually on econ (i.e. no air conditioning) with the fan speed on 1 or 2 'bars'. That is enough to circulate the air. If it gets hot then I'll turn the econ off i.e. switch to aircon mode. I rarely use full climate control (i.e. AUTO) as the fan speed is usually quite high and the noise bugs me hence I use it in manual mode Quote Link to comment Share on other sites More sharing options...
nordberg Posted August 1, 2006 Author Report Share Posted August 1, 2006 I feel stoopid. I didn't realize what the econ button did RTFM springs to mind Quote Link to comment Share on other sites More sharing options...
