Oatz Posted August 11, 2006 Report Share Posted August 11, 2006 ....of removing the wheel centre caps without actually damaging the wheels themselves? Many Thanks chaps Link to comment Share on other sites More sharing options...
Oli Posted August 11, 2006 Report Share Posted August 11, 2006 Take the wheels off and push from behind! Link to comment Share on other sites More sharing options...
khutula Posted August 11, 2006 Report Share Posted August 11, 2006 Do you want to use the centre caps again? I replaced mine recently and struggled to remove them, but as they were completed knackered, I screwed a self tapping screw a few turns into the caps. They were easy to pull out then. One was a bit tougher - so I just pulled on the screw with a pair of pliers.. Link to comment Share on other sites More sharing options...
Oatz Posted August 11, 2006 Author Report Share Posted August 11, 2006 [ QUOTE ] Take the wheels off and push from behind! [/ QUOTE ] The operative word was EASY.... but cheers anyway Link to comment Share on other sites More sharing options...
Oatz Posted August 11, 2006 Author Report Share Posted August 11, 2006 [ QUOTE ] Do you want to use the centre caps again? I replaced mine recently and struggled to remove them, but as they were completed knackered, I screwed a self tapping screw a few turns into the caps. They were easy to pull out then. One was a bit tougher - so I just pulled on the screw with a pair of pliers.. [/ QUOTE ] Perfect not intending to use again as I managed to acquire some new one's under warranty, Thanks Link to comment Share on other sites More sharing options...
khutula Posted August 11, 2006 Report Share Posted August 11, 2006 No worries Link to comment Share on other sites More sharing options...
rs32 Posted August 11, 2006 Report Share Posted August 11, 2006 plastic trim-remover tool ? Link to comment Share on other sites More sharing options...
