How much a corner??
seventyseven
.....is the most/least any of you have paid for tyres??
And ££ what did you pay for what brand?
I do about 14k p/a & looks like I'll be on A new set of boots for the front every year,WITHOUT any welly!!
Gulp!!
OliH-Does your emporium of yts trained spanner monkeys also do tyres of joyful cheapness??
Try
www.mytyres.co.uk
When I had 18s, KiwkFit wanted £167 per corner for F1s or Potenzas, Mytyres did them for £105 per corner.
So, at approx £420 - £460 for a set per year, I think that is very good value!
Last week I had a new front due to a puncture, 4 weeks old and £126 but the problem was finding a fitter who had the correct machine. I found a guy in Nottingham that uses the Corghi AM26 fitting machine, this can change anything up to 26" without touching the rims. Another problem is whether to change the metal valve, so I decided to buy a spare from the dealer just in case as tyre fitters only use the standard black plastic.
All in all good fitting from ETS in Nottingham.
I believe the tyre pressure sensing is done by the ABS sensors detecting a change in rolling circumferance. It therefore only works while the car is moving.
Surely the physical circumference of a tyre can never change. The distance travelled by one revolution of the tyre should be the same regardless of inflation pressure.
Unless I'm wrong of course...
no, the physical rolling circumference changes according to the tyre pressure when the tyre is on the car.
if one tyre deflates, that wheel has to rotate a bit more than the correctly pressured ones to travel the same distance.
this discrepency is monitored by the abs sensors leading to a tyre pressure fault warning light.
I don't believe it does. Imagine a tank track - the distance travelled by one revolution is the same regardless of what shape it forms. A flat tyre has the same circumference as an inflated tyre - it's just a different shape.
