How to clean your car with 1 bucket of water
Daz
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
got the same set up from a 25 l container.
I have a copy of this from Thames water, incase anyone kicks up, although i dont use pressure washer every time...
Current legislation, underlined in the Section 76 of the Water Industry Act
1991, prohibits the use of a
hosepipe to water private gardens or wash private vehicles.
As your pressure washer will not be connected to the mains supply, and the
water will be supplied
from a static container you will not be in breech of any bye laws.
However, only short lengths of
hosepipe, approximately 3-4 feet in length, may be used in order to fill
any static containers, including
buckets and watering cans.
I hope this information is helpful.
so ive made sure the hose from the container to the pressure washer is also less than 3 foot.
I use one and a bit, but ive only used it 3 times for deep clean.
I modifed the screw cap on the barrel fo fit a hoselock fitting, and draw tube, with a vent hole to stop the barrel collapsing.
its suprising how far the water goes with a pressure washer.
I am convinced i use far more with buckets and watering can method.
Get yourself the foam lance to go with it too, for maximum efficiency when washing! Will never go back to a bucket of flat suds ever again!!!
Is there a particular type of shampoo needed for a pressure washer? I used my Karcher last night which has the integrated detergent tank and the regular vario lance. Tinkered around with the mix settings and had the foam setting on the lance but the Meg's shampoo I was using hardly had a bubble in it. Certainly not a nice "foam".
I use the detergent tank for rinsing off with Karcher Wash & Wax, although B&Q have stopped selling it and their own-brand is cack. I need to buy some online, it's like automotive washing crack cocaine - once you try it, there's just no alternative. Just fill the detergent tank before your last rinse, and then do a quick high-pressure rinse followed by a low pressure rinse with the standard vario lance, and the wax is deposited onto the paintwork and the water just beads off. Ten minutes with a chamois and you have a clean and waxed car, and it smells great too - really complements the fruity smell of Zymol.
I used the Megs shampoo with the foam lance (£14.99 from Halfords) and it seems to work well. Never got on with using the detergent tank.
Thanks guys, I saw those in a Halfords store the other day but thought it looked so "cheap" that it couldn't actually be of any use. My bad, I'll go and get one this evening. slap.gif
Does it just clip onto the trigger assembly in place of the regular lance?
Cheers!
Sounds good. I think I saw that in Halfords or Homebase the other night. Again, I just made the assumption that because it wasn't a designer (Meg's, Zaino, whatever) brand that it was probably just Karcher trying to cash in and it couldn't possibly be any good. suicide.gif
Yep, that's it. They do tend to empty themsleves quite quickly, but the foam it produces is like the foam on those spray washers at petrol stations - lots of it and nice and sticky so it doesn't just run off the car.
The Karcher Wash & Wax is the bight pink stuff in a 5L tub. Honestly, I love the stuff as you can be lazy and do your waxing at the same time as washing (not the right attitude for the detailing forum, I know! blush.gif ).
I know exactly where you're coming from. Lets not call it "lazy" but something more like "labour saving". Nothing wrong with saving some of the detailing pain during a regular weekly wash.
