vanillaice Posted September 6, 2006 Report Share Posted September 6, 2006 Hi, I am looking at buying an S3 from AT. It currently has ~30k miles on the clock. I am aware that Audi offer two type of servicing. Is it possible to judge when the next service is likely to be? The car is on a 51 plate. Any advice, gratefully received. Cheers, ICE Link to comment Share on other sites More sharing options...
Wallachie Posted September 6, 2006 Report Share Posted September 6, 2006 If it's on AVS servicing, it will be due around 34,000 and the 2nd AVS will cost between £450-500 from an Audi dealer, less from a specialist, perhaps £300+. The Haldex oil and filter need changed at the 2nd AVS which makes it expensive. If the car is on annual servicing, you should be able to work that out (approximately) from the date of registration. If the car is a 51 plate, it's unlikely to have any warranty, so I would use a specialist to do the work. Edit: just realised, the car is probably about 5 years old with 30k miles, it is most likely on annual servicing! Link to comment Share on other sites More sharing options...
Paul Posted September 6, 2006 Report Share Posted September 6, 2006 press the left stalk, whilst igniton on but car not moving... does it tell you? it will with AVS variable servicing. Not sure what it does with annual, never had it. Link to comment Share on other sites More sharing options...
