What about a sunroof?
prt57
Hi, just thinking about the spec on the R32 that I am hoping to order.
My current GTI has a light headlining and a sunroof so lots of light streams in. Also quite nice to have it wound back for lots of fresh air.
A new R32 has a dark headlining, is it gloomy and would the light from the sunroof be of benefit?
Thanks for your thoughts, prt.
Not had a sunroof in my previous 2 cars and not missed one. As you say, it's only really for light as the climate control sorts the temperature. Personally I would rather put the money into another optional extra. A sunroof is of greater benefit to passengers IMO - when I'm driving I don't notice light levels in the car to be honest. 169144-ok.gif
The sunroof on the Mk5 R32/GTI is especially good. Even when closed, it's nice to let some extra light in - In fact in a year I have never closed the solid internal panel once.
It has all the settings you would expect and is even good at speed if you let down a rear window just a centimetre to release air pressure build up - For 3-door cars use the front window.
It's a glorious blue skied sunny day today and I've had my sunroof fully open this morning. 169144-ok.gif
Looks like a sunroof is now on the Menu.
I have a test drive sorted for Saturday where one of the things that I will check out is will an R32 drive up onto my drive without scratching the front valance. We have a fairly steep drive up off the road and I need to rest this out. My neighbour has a TT and has no trouble if he takes it slowly as we have a shared drive.
What do you think, is a TT higher or lower at the front than an R32.
Hopefully I will be able to give it some beans on the way back to the garage. It is a DSG model and I would order manual but beggers cannot be choosers!!
Keep your thoughts coming, prt.
