Milo Posted September 9, 2006 Report Share Posted September 9, 2006 Would claying a car and then applying Stage Meguiars 2 strip off Autoglym Lifeshine Protection sealant or is it durable enough to withstand it? Link to comment Share on other sites More sharing options...
NewNiceMrMe Posted September 9, 2006 Report Share Posted September 9, 2006 Ultimately, after consistent use of Stage II, I'm pretty sure it'll wear the Lifeshine sealant off. It does, after all, state that it removes any need for polishing and waxing for 10 years. Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted September 9, 2006 Report Share Posted September 9, 2006 Lifeshine doesn't remove the need for polishing / waxing etc. - AG recommend you polish & seal as usual. Probably worth emailing AG about it. I've contacted them previously and they usually respond in a couple of days. Link to comment Share on other sites More sharing options...
steelwind101 Posted September 10, 2006 Report Share Posted September 10, 2006 Hi Lets be clear on this. Megs stage 2 is fine to use as often as you want. It is a "PURE POLISH". That means it has ZERO abrasives, you may also know this type of product as a GLAZE. As far as claying goes, in many cases this will remove waxes and sealents. The effect it will have on LifeShine i do not know. Many people get away with a fine clay which can be used on a regular basis is very light in what it does. This may help you. Geoff Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted September 11, 2006 Report Share Posted September 11, 2006 [ QUOTE ] Hi Lets be clear on this. Megs stage 2 is fine to use as often as you want. It is a "PURE POLISH". That means it has ZERO abrasives, you may also know this type of product as a GLAZE. As far as claying goes, in many cases this will remove waxes and sealents. The effect it will have on LifeShine i do not know. Many people get away with a fine clay which can be used on a regular basis is very light in what it does. This may help you. Geoff [/ QUOTE ] Well that's my present understanding rightly or wrongly! Link to comment Share on other sites More sharing options...
