how'd i get rid of these marks?
skanky
Hi
If you have streaks left from using a QD you have probably used too much. They are water based, you can just wash your car and they will be gone.
Also if you have scratched your car or caused swirl marks from being aggressive with a QD Megs. stage 2 WONT HELP you.
It may help hide the marks, but it wont remove them.
Megs stage 2 is a "PURE POLISH". That means it has ZERO abrasives, you may also know this type of product as a GLAZE. Use it as often as you want, it WONT remove a thing.
The most aggressive product you can OTC (over the counter) in the Megs range right now is ScratchX which is pretty weak. Aggressive swirl and scratch removers are found in the beige megs. bottles in the pro. range.
Hope this helps.
Geoff
picked up megs step1 and step2, so intend to follow the process outlined in the "Meguiars - Gold Class, NXT or Stage 1-3 ?" thread hopefully this weekend.
thats the last trip im making to halfords! i think i've developed "MCD", was supposed to goto argos to return something but instead somehow convinced myself to make a detour to get more megs stuff, argh!
