Gear knob changing
takamine
Take the ash tray out and undo the two visible screws and remove the decorative panel. You'll then we able to ease the area around the gearshift gator out. Once removed you can take pull it up I.e. turn it inside out and you'll see a metal clamp holding the gear knob on. Cut this and it will all come away.
I think you have to change the whole gator as well....at least that's what I did.
p.s. the above is from memory so should be close if not 100% accurate.
