which engine oil?
prel200
Went to the stealers today to purchase an oil filter and enquire about the oil. (Could not believe how rude the parts assistant was..!!)
Anyway I am told that my car was serviced with long life oil and only requires changing when prompted by the computer/service light in the car as it is variable servicing. I still insisted that i wanted to change the oil particularly due to the remap and he then said well it will cost £70 a gallon..!! what kind of oil was he trying to sell me.??!! Anyway i walked out without purchasing as he was just too rude..!!!
Can anybody advise exactly what oil to use and how much it will really cost me??
I have been advised not to use the longlife oil, just use a standard oil and change it every 5k. Obviously do this yourself and not at the stealers. Longlife oil is used to lengthen the service intervals and it is full of addatives that keep the soot in suspension which you don't want really.
I'll post up when my expert tells me which oil to use
He needs to use an oil that is the same spec as the one listed in his manual, for his car. He can then buy whatever brand he wants, as long as it meets the spec.
So unless he wants to use a non-spec oil it doesn't matter what everyone else uses.
He needs to get his manual out, or wait for someone from this forum that knows what spec he needs, e.g. they have the same engine/car, or are just plain knowledgeable. znaika.gif
While you were at the dealer, you could have asked him what spec oil you needed.
