Dan32 Posted September 14, 2006 Report Share Posted September 14, 2006 Just been to APS again. Changed the faulty lambda probe in the exhaust (£100 from VW!) and fitted the Milltek hi flo cats. You can see damage in the original ones. Car now runs a lot better, although I did manage 30.8mpg with the EPC light on on the way to APS! Car also louder and quieter. Louder when you accelerate or blip the throttle but its quieter at motorway cruising speeds having taking out a bit of the boominess. Only slight niggle is the rattle coming from what Ed thinks is the heat shield attached to the cats. He said they've only ever seen 1 other do it but its straight forward fix. Oh well, any excuse to go back up there and get them to put on more parts Link to comment Share on other sites More sharing options...
Roughnec Posted September 14, 2006 Report Share Posted September 14, 2006 What the hell caused damage like that! Link to comment Share on other sites More sharing options...
khutula Posted September 14, 2006 Report Share Posted September 14, 2006 Have you applied you your parking permit at APS yet Dan? Good work Link to comment Share on other sites More sharing options...
TP27 Posted September 14, 2006 Report Share Posted September 14, 2006 [ QUOTE ] What the hell caused damage like that! [/ QUOTE ] Was thinking the same, heat ? Link to comment Share on other sites More sharing options...
Dan32 Posted September 14, 2006 Author Report Share Posted September 14, 2006 Nathan was saying that the faulty probe allowed more fuel into system which obviously gets very hot and starts to destroy cats. I'm sure that the damage you can see is the same as any other damaged cat I've seen on the web. Lesson to us all to be aware of poor running and bad mpg as this can often be a sign something wrong. Had the probe been replaced quickly enough, the cats would have survived but then I wouldn't have hi flo cats and designated parking spot at APS. Hope to be getting my own monogrammed mug there next!! Link to comment Share on other sites More sharing options...
Oatz Posted September 14, 2006 Report Share Posted September 14, 2006 [ QUOTE ] Nathan was saying that the faulty probe allowed more fuel into system which obviously gets very hot and starts to destroy cats. I'm sure that the damage you can see is the same as any other damaged cat I've seen on the web. Lesson to us all to be aware of poor running and bad mpg as this can often be a sign something wrong. Had the probe been replaced quickly enough, the cats would have survived but then I wouldn't have hi flo cats and designated parking spot at APS. Hope to be getting my own monogrammed mug there next!! [/ QUOTE ] Glad to hear you've got your problem sorted out Dan and the perfect excuse to get the hi-flo's on there Link to comment Share on other sites More sharing options...
khutula Posted September 14, 2006 Report Share Posted September 14, 2006 I've seen a thread on here that showed Decked's cats when he had them replaced and they were even worse than this. Edit to include link to other thread Link to comment Share on other sites More sharing options...
Decked Posted September 14, 2006 Report Share Posted September 14, 2006 I had the same problem!!!!! Link to comment Share on other sites More sharing options...
Decked Posted September 14, 2006 Report Share Posted September 14, 2006 [ QUOTE ] I've seen a thread on here that showed Decked's cats when he had them replaced and they were even worse than this. Edit to include link to other thread [/ QUOTE ] Doh!!!! Link to comment Share on other sites More sharing options...
pomme Posted September 14, 2006 Report Share Posted September 14, 2006 Humm, youve got me thinking now as i had a faulty probe and they have just put a new one in, but if the fault appears again, ill def get them to look at the cats. Link to comment Share on other sites More sharing options...
Brisel Posted September 14, 2006 Report Share Posted September 14, 2006 Which end of the cats are the images looking at? I will get mine checked out when I get my rear Milltek fitted. How do you know if they are fecked otherwise? When it fails an emissions test during its' MOT or roadside check? Link to comment Share on other sites More sharing options...
Dan32 Posted September 14, 2006 Author Report Share Posted September 14, 2006 Can't remember which end that is although guessing its the manifold end looking back towards the silencer end. I think main way to check for damage is to run diagnostics on the car which will throw up fault codes. I may have damaged the cats over a long period of time with the faults I had. Link to comment Share on other sites More sharing options...
Mook Posted September 18, 2006 Report Share Posted September 18, 2006 [ QUOTE ] Which end of the cats are the images looking at? [/ QUOTE ] The end that's been photo'd is the end that connects to the manifold downpipe (i.e. the first part of the cat that gets hit by the exhaust fumes. On the other end there's a two foot(ish) pipe which merges into one to connect to the centre section of the exhaust. Link to comment Share on other sites More sharing options...
