Atomic Posted September 25, 2006 Report Share Posted September 25, 2006 Firstly let me describe the noise... It's like a low volume whine you would get get if you was inside a jet plane taxing along ready for takeoff... It only happens when they heating system has the aircon switched off. If you switch to the economy mode it dissapears very quickly - but not instantaneously. If you switch on the aircon it returns within 2-3 seconds, e.g. the time it probably takes for a component to spin up and the noise work it's way around the system. Secondly it's erratic, some days it does it, some not... I'd guestimate it happens around 1/3 of the time. It is also most noticeable at around 1500 rpm in the lower gears. You can some hear it at lower engine revs but it's much quieter. Above 1500 it slowly dissapears, mainly I suspect due to being drowned out by the engine. It also to some degree changes it's tune with the engine revs - it doesnt for however directly follow the revs - eg it's not twice the frequency at twice the revs. To me would tend to indicate it's not being caused by an electical fan, albeit high revs do raise the alternator output voltage a little which could have the desired effect. Any ideas? Thanks, Paul. Quote Link to comment Share on other sites More sharing options...
Ska Posted September 25, 2006 Report Share Posted September 25, 2006 Are you able to pin point the location of the noise? Is it comming form the centre of the dash towards the front? if so may be the blower. The only difference between econ mode and normal opperation is the compressor switching off so could it be the pulley clutch mech etc? will have a look when I get home Quote Link to comment Share on other sites More sharing options...
Atomic Posted September 25, 2006 Author Report Share Posted September 25, 2006 It does sound pretty central, mainly from the central 3 vents. What sort of clutch is it? mechanical or viscous? Quote Link to comment Share on other sites More sharing options...
Jools Posted September 26, 2006 Report Share Posted September 26, 2006 I think i had the same problem, turned out to be the little electric water pump that pumps the water round when the rest button is pressed. located in the engine bay under the heater matrix cover to the right hand side. You can just see the tops of the motors if you look in. Hope this helps. Jools Quote Link to comment Share on other sites More sharing options...
Atomic Posted September 26, 2006 Author Report Share Posted September 26, 2006 How much did it cost to get fixed and did you have any other symptoms? Quote Link to comment Share on other sites More sharing options...
Will22 Posted September 26, 2006 Report Share Posted September 26, 2006 [ QUOTE ] It only happens when they heating system has the aircon switched off. If you switch to the economy mode it dissapears very quickly - If you switch on the aircon it returns within 2-3 seconds [/ QUOTE ] You have contradicted yourself there, does it make the noise when the aircon is on(not in econ mode) or when it's off(in econ mode) If it only does it when the aircon is on then I have the same thing, it was also in the 4.2 sport I had a few years back. It made the noise all the time I had the car from around 30k up to 190k miles. The only time you could hear it was when you were in traffic and moving very slowly or stoped. When you pressed the econ button it would stop and likewise when you pressed auto it would come back but take a few seconds to do so. At times it used to drive me mad(times when I didn't want any music on) I lived with that for ages when I could of had it fixed, dam I knew I should have asked Audi about it. Quote Link to comment Share on other sites More sharing options...
Atomic Posted September 26, 2006 Author Report Share Posted September 26, 2006 Sorry yup, it only does it with aircon on. Sounds like I'm not alone though but I dont get it when stopped, just moving slowly - as mentioned around 1500 rpm. Quote Link to comment Share on other sites More sharing options...
Will22 Posted September 26, 2006 Report Share Posted September 26, 2006 Dean, this is what vagcom is http://www.ross-tech.com/ or try looking here http://www.tyresmoke.net/ubbthreads/postlist.php/Cat/0/Board/VagCom Quote Link to comment Share on other sites More sharing options...
Ska Posted September 26, 2006 Report Share Posted September 26, 2006 Whats going on, Will? me heads spinning is there some cross posting going on here Quote Link to comment Share on other sites More sharing options...
Will22 Posted September 26, 2006 Report Share Posted September 26, 2006 [ QUOTE ] Whats going on, Will? me heads spinning is there some cross posting going on here [/ QUOTE ] Sorry, it's me the muppet Quote Link to comment Share on other sites More sharing options...
ng_lag Posted January 21, 2007 Report Share Posted January 21, 2007 Hi, did anyone ever get to the bottom of the cause of this issue? Quote Link to comment Share on other sites More sharing options...
