markobyrnes Posted November 12, 2006 Report Share Posted November 12, 2006 Hi there. I'm trying to remap the passat ecu but the program tells me to pull out fuse 11. In my car there is no fuse in no 11! You have to disable the instrument cluster and I have pulled out every fuse and the instrument cluster stays lighting. Any ideas? I accessed the fuse panel at the door and under the dash but nothing kills the instrument panel! The program recognises the type of ecu etc, but I can't read or write at this stage it says pull out fuse 11 if I go further it says ecu not found! Link to comment Share on other sites More sharing options...
shark_90 Posted November 12, 2006 Report Share Posted November 12, 2006 Have you tried disconnecting the plugs from the back of the cluster? Just an idea Link to comment Share on other sites More sharing options...
markobyrnes Posted November 12, 2006 Author Report Share Posted November 12, 2006 Hi Shark 90 No I didn`t try disconnecting the plug from the cluster. May try it. I wonder why would you have to remove the fuse anyway? pain in the ass! Link to comment Share on other sites More sharing options...
