Porter cable - £111.76 delivered
adigraham
Found this:-
Item# Qty Description Unit Price Total
7424 1 Porter-Cable 7424 150mm Variable-Speed Random-Orbit Polisher £ 83.33 £ 83.33
Subtotal £ 83.33
Fedex_Express Posting £ 28.43
All VAT Included £ 0.00
Total Price Delivered £ 111.76
Isn't this cheaper then the states?
This comes from the states (despite it saying it's a UK site), you'll probably get hit with a big duty bill. The best deal is from Autopia.
BOOSTER: No UK product b/c of CE mark required + 240V as opposed to 110 USA. Megs. UK are working on a UK version of the porter cable avalible 2007. When exactly i dont know.
Personally i use CYCLO they do a uk version £215 its to Porter Cable hears on one device.
No varible speeds, just an on off switch. This has its ups and downs, i had a PC which broke and went up to this. It has a bit more bite b/c of the dual heads. If you imagine sweeping left to right with it and then using some OPTIMUM. Polish with the right pads you can achieve excellent results.
Pads are different to the PC ones, £50 will get you large set of pads. Device is heavier then the PC but not heavy, which means no down force required on the flat surfaces.
No voltage adapeters required, fully warrentied in the UK avalible from www.MOTORGEEK.CO.UK
Well worth considering if you want to remain with the "safety of random orbital" with a bit more kick.
Geoff
or you could consider a biltema which is a repackaged cyclo as mentioned by steelwind, but it costs something like £30 in norway / sweden etc and has 6 speeds. Only issue is they dont ship to the UK so you have to find someone to do it for you, oh and its 240V (just change a plug).
