Standard Headlights
lmmlmmam
Lovin' my new toy but... is it me or are the standard headlights pretty dung.gif?
The dipped beam in particular is woefully dim.
They seem to be set somewhat high as well which is making maters worse.
Have I made a mistake in not getting a car with Litronics? I've had Xenons on my last two cars but regularly drive my wifes car with Halogen lamps and never felt with that any major loss.
I've read in the manual how to adjust the beam. Does anyone know what size Allen key is required to do the job?
I'm tempted to fit some better bulbs (Osram Silverstar?). Is the removal/replacement of the units relatively straightforward?
TIA
CM
Thanks Rachel! Good to know that the Halogen lamps shouldn't be awful. Can't think why it would be country specific, although I guess they may multi source the bulbs. Is your's also H7 bulb for dip & H9 for main.
I've just heard this morning that one of my headlights is going to be replaced under warranty (due to minor staining on the inside of the glass). Hopefully this will help. They'll also check the alignment whilst it is in.
If they are still poor I'll be replacing the bulbs.
You might be right about the globe sourcing - I must admit I haven't taken mine apart, so cannot answer you w.r.t. H7/H9. frown.gif
They are as good as the R32's Xenon/Halogen combo - probably actually better on the roads down here in the wet as the R32 Xenon's do not light up the roadside/curbs very well when it is wet. The yellower light of the halogens does a much better job of this.
