pass130 Posted November 20, 2006 Report Share Posted November 20, 2006 recently picked up a Tdi 130 estate, 2001, 80k, goes ok, with full rev range, but with a slight flat spot mid 2200 revs, mpg 36 (urban) compared to my last 110tdi this feels a bit lethargic and no real go about it; MAF sensor issue? cheers Link to comment Share on other sites More sharing options...
Rustynuts Posted November 21, 2006 Report Share Posted November 21, 2006 Certainly sounds like it. Give it a spin with the maf disconnected and see what it's like. If it's better or about the same then you need a new one. If it's worse, then you still might need a new one to sort out the flat spot. Link to comment Share on other sites More sharing options...
pass130 Posted November 21, 2006 Author Report Share Posted November 21, 2006 unplugged sensor, car completely flat, plugged back in and well its better, but not as lively as I think it should be, worth a new sensor? Link to comment Share on other sites More sharing options...
Pa55aT Posted November 21, 2006 Report Share Posted November 21, 2006 Hi I've just had a similar problem with my 130. It was sluggish upt 3,500 revs and then picked up a bit. Garage have found a vacum hose had split. Just another possibility Thanks chris Link to comment Share on other sites More sharing options...
pass130 Posted November 21, 2006 Author Report Share Posted November 21, 2006 thanks for that, will check the hoses over before i do much else. Link to comment Share on other sites More sharing options...
ChrisBradburn Posted December 8, 2006 Report Share Posted December 8, 2006 [ QUOTE ] I've just had a similar problem with my 130. It was sluggish upt 3,500 revs and then picked up a bit. Garage have found a vacum hose had split. [/ QUOTE ] Which hose? Did they tell you? Link to comment Share on other sites More sharing options...
