Rear cup holders - A6 Avant ??
tappers
I see from your sig yours has RNS-E, and that yours is the 180BHP version, would I be right in saying you already had the double DIN space in the front?
I would like to get RNS-E installed if not too costly but unsure about the doulbe din Conversion??
No need to remove the rear seat ...there is an audi bulletin on these which if I can find will post details on.
Essentially - I think you take the outer trim away ( the piece around the two cups maybe ..if not then the cupholder fronts) ...then they can be released much the same as the front ones with the radio tool ( and if you don't have one of those the metal from one side of a suspension file ( from a filing cabinet if anyone still has these) cut down wit a 30-45 degree slope will do the job).
Alternatively...mine are slow /reluctant to come out ...but if I wallop the seat with my fist above the cupholders they come out slowly and just enough to get them out all the way.
Replacements are something like £15 -£20 (each) from dealers last time I looked...
Yeah, we had the in-dsh 6 cd changer so it was already a double din sized hole.
I'm sure Craigyb has done single-to-double din conversions. Drop him a PM
