2004 A4 HID Headlight adjustment
smjohns
Sorry if this has been asked before, I have tried searching but could not find anything.
How do you go about changing the A4 HID headlights for driving in Europe? Is there a lever at the back or inside the light unit or is this a dealer only change.
Do regular Europe travellers bother modifying their lights these days?
Any help will be greatly appreciated.
Cheers
Si
Thanks for that kite. Out of interest, when you say they just slide over the dipped beam projector part of the headlamp how do they attach? Do you need to open up the light unit or are they like static window stickers that just attach to the front of the unit?
I've got a set of the Audi deflectors which I no longer need (they won't fit my B7 RS4). Only used once for 2 weeks in June/July in France.
They DO stick on - they came with two thin strips of double sided tape top and bottom. But as the tape only works one time, you need to fit new tape each time you use them.
  • 1 year later...
Sorry if this is a bit of a "dead thread" but wondered what the current solution to beam conversion on the B7 RS4 - Audi dealer wants £58 to do the switch - oh and £58 to do it back!! Seems a bit steep so wondered if Super Beam Benders or similar actually work?
If you have adaptive lights on your RS4 (like I do) then I don't spend a penny when I go abroad - with VAG-COM I enable "Tourist Mode" while I'm waiting at the port on the way out and reset it on the way back.
  • 1 year later...
  • 1 year later...
Does the tourist mode only work on the adaptive lights? Not on the regular xenons on an '04 S4?
I assume I'll be looking for a switch/lever otherwise when I head to the continent next year...
S4_marv -
Did you manage to sort something for this? My 04 plate A4 is going over to France this year and I can't work out from all the various posts what works, what doesn't etc.
I've only got tourist mode to work on adaptive lights.
Of the two B6 S4s I had one had levers (the 2003 one), the other didn't (the 2005 one).
