wyliss Posted November 22, 2006 Report Share Posted November 22, 2006 Any of you guys have an idea on when the car would need one of its most expensive services i.e. cam belts and other bits etc?. Trying to guage what a car with about 40k on the clock would possibly need. Cheers Link to comment Share on other sites More sharing options...
cabboy Posted November 22, 2006 Report Share Posted November 22, 2006 Model ? Engine Size ? Year ? CB Link to comment Share on other sites More sharing options...
Cupramax Posted November 22, 2006 Report Share Posted November 22, 2006 Exactly the same as a normal A4. There's no difference in servicing a cab to any other A4. The cambelts are being changed by dealers at 4 years now accoring to some posts on here. The 40k service is usually a big one. If your buying a 40k car dont get it without having this done... Link to comment Share on other sites More sharing options...
wyliss Posted November 22, 2006 Author Report Share Posted November 22, 2006 CB its a 3.0 on 2003 plate with 41k on clock at a dealer Link to comment Share on other sites More sharing options...
cabboy Posted November 23, 2006 Report Share Posted November 23, 2006 In that case, as suggested above, make 110% sure it's had the 40k service done as that's a pricey one. CB Link to comment Share on other sites More sharing options...
wyliss Posted November 23, 2006 Author Report Share Posted November 23, 2006 Would any of you guys happen to have a copy of exactly what needs to be done at this service? Cheers much appreciated ! Link to comment Share on other sites More sharing options...
Nelson_R32 Posted November 23, 2006 Report Share Posted November 23, 2006 [ QUOTE ] Would any of you guys happen to have a copy of exactly what needs to be done at this service? Cheers much appreciated ! [/ QUOTE ] The parts listing is as follows... 20k Service; Oil Filter Sump Plug Pollen Filter 40k Service; Oil Filter Sump Plug Pollen Filter Spark Plugs 60k Service Oil Filter Sump Plug Pollen Filter Air Filter This works on a rotational basis, so your 80K service would be a Cambelt and the basic AVS 1 (20k) type service. Then 100k would be AVS 2 (60k type) etc etc Link to comment Share on other sites More sharing options...
wyliss Posted November 24, 2006 Author Report Share Posted November 24, 2006 Hi Nelson, Looking at the previous posts they mention about belts needing to be replaced around the 40k mark....if so which additional parts are required to the list you have already mentioned? Cheers Link to comment Share on other sites More sharing options...
