dukeboy749r Posted November 22, 2006 Report Share Posted November 22, 2006 20. The two most useless things to a rider are the braking distance behind you and nine-tenth of a second ago. 19. Remember, gravity and centrifugal force are not just a good ideas. They're laws and are not subject to appeal. 18. Keep looking around. There's always something you've missed. 17. Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment. 16. In the ongoing battle between objects made of metal, rubber and fibreglass going 100+ miles per hour and the ground going zero miles per hour, the ground has yet to lose. Same holds for cars, large trucks, and animals taller than you. Draws don't count. 15. If all you can see in your mirrors is sparks and all you can hear is screaming from your passenger, things may not be as they should be. 14. You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck. 13. There are two simple rules for riding smoothly and fast in snow and on ice. Unfortunately no one knows what they are. 12. Always try to keep the number of times you put your sidestand down equal to the number of times you put the sidestand up. 11. Never let a motorcycle take you somewhere your brain didn't get to three seconds earlier. 10. You know you've left the sidestand down when all left turn are Bat-turns. You know you've left the centerstand down when your in 1st gear at 4000 rpm going nowhere. 9. Learn from the mistakes of others. You won't live long enough to make all of them yourself. 8. When in doubt slow down. No one has ever hit something too slow. 7. The rear wheel is just a big fan on back of the bike used to keep the rider cool and his/her butt relaxed. If going into a corner too fast, slamming on the rear brake causes the "fan" to abruptly stop. When this happens you can actually see the rider start sweating and his/her butt become tense. 6. The only time you have too much fuel is when you're on fire 5. It's always better to be on the sidelines wishing you were on the track than on the track wishing you were on the sidelines. 4. Riding isn't dangerous. Crashing is dangerous. 3. If you push the bars left, the bike goes left. If you push the bars right, the bike goes right. That is, unless you continue pushing the bars all the way, then the bike will go down. 2. Every ride is optional 1. A 'good' ride is one from which you can walk away. A 'great' ride is one after which you can use the bike again. Link to comment Share on other sites More sharing options...
Omi Posted November 22, 2006 Report Share Posted November 22, 2006 Awesome, top tips. Link to comment Share on other sites More sharing options...
Avus_Bub Posted November 22, 2006 Report Share Posted November 22, 2006 Great! Link to comment Share on other sites More sharing options...
Doctor46 Posted November 23, 2006 Report Share Posted November 23, 2006 Most amusing, and flaming right too! Well done. Link to comment Share on other sites More sharing options...
Lee_ Posted November 23, 2006 Report Share Posted November 23, 2006 Spot on Link to comment Share on other sites More sharing options...
badgera Posted November 23, 2006 Report Share Posted November 23, 2006 [ QUOTE ] 3. If you push the bars left, the bike goes left. If you push the bars right, the bike goes right. That is, unless you continue pushing the bars all the way, then the bike will go down. [/ QUOTE ] Sorry to be a smart but this isn't true, at speed if you push left you lean right and go right and if you push right you go left. Physics and Gyroscopic effects in-it. Thats why inexperienced riders got too fast into a turn and then force the bars into the turn to get around it, even though all this does is stand the bike up and aim it for the hedge. Link to comment Share on other sites More sharing options...
dukeboy749r Posted November 24, 2006 Author Report Share Posted November 24, 2006 [ QUOTE ] [ QUOTE ] 3. If you push the bars left, the bike goes left. If you push the bars right, the bike goes right. That is, unless you continue pushing the bars all the way, then the bike will go down. [/ QUOTE ] Sorry to be a smart but this isn't true, at speed if you push left you lean right and go right and if you push right you go left. Physics and Gyroscopic effects in-it. Thats why inexperienced riders got too fast into a turn and then force the bars into the turn to get around it, even though all this does is stand the bike up and aim it for the hedge. [/ QUOTE ] Sorry, yes good ole countersteering... Link to comment Share on other sites More sharing options...
