UN'LEADED FUEL IN MY DIESEL ENGINE
legionrecrue
Did you run the engine till you realised there was white smoke pooring out the back?
If you didn't run the engine, then simply empty the tank and replace the filter for good measure, if you ran it... you may need to replace the fuel pump.
I'm no expert on the ford diesel, but when one of the guys put 70 litres of unleaded in his Toyota Landcruiser 3.0TD, it needed a new fuel pump too.
Bad luck mate...
hi Legion - yes you are a right plonker grin.gif but welcome to TSN 169144-ok.gif
IIRC a small bit of petrol in a diesel is far less of a problem than diesel in a petrol. If you get it flushed immediately and also get the right advice on parts that could have been affected then you may well find there's no lasting damage smile.gif
p.s. just so you know the capital letters come across as "shouting" - your posts will get far better responses if you take the time to write them in normal case 169144-ok.gif
Wrong way round RS32. Petrol in a diesel is real bad news. Petrol is a solvent whereas diesel is a lubricant. The lack of lubrication to the fuel pump can knacker it if it's started up and run. You can get the tank drained, flush the fuel lines, replace the filter, and cross your fingers. If it runs ok then you're close to a result. If it runs like a bag of spanners then you'll be out for a new fuel pump.
Have to say out of all the diesels i have removed petrol from, Only ever had 1 that done serious damage! Usually the lift pump in the tank burns out before the injection pump and injecters get damaged. You the fact that you stopped it before it cut out is good. A garage will still charge you a few hundred buks im sure to drain system, refill and bleed, fit filter and then charge you to dispose of the contaminated diesel.
maybe i should just think about rigging it with a piece of flex, a battery and detonator, less expensive
Welcome legion, good luck with sorting the car. I have fears of doing this as I have a diesel for work and just know one day I'll put diesel in the TT when I'm half asleep.... UHOH7.GIFEEK2.GIFgrin.gif
My husband did this a couple of years ago he filled it right up and drove it until it wouldn't move anymore smashfreakB.gif
then realsied what he had done but it only cost £100 to drain and it was fine.
Yours is a VAG diesel, so different type of system. According to Mr Mulk they don't suffer from this as they cut out before any damage is done. Good old VW, eh. Ford on the other hand....
