compbuild Posted November 23, 2006 Report Share Posted November 23, 2006 Hi I’ve got a 2002 Golf TDI (ADT I Think). The problem is the cold start has gotten pretty poor it starts fine but there is a bit of smoke and the engine revs like the accelerator is being pumped a bit, much like the effect a an old choke would have had then when I move off it is pretty juttery for several hundred metres. I think the MAF sensor has gone as well as the car has started to die on the motorway and do a top speed of just over 80 at about 2200 rpm. Are these problems related or any advice on how I can sort it? Is the MAF sensor a DIY Job I’m quite a novice at car maintenance but have changed Oil, filters, belt etc before. Any help much appreciated Link to comment Share on other sites More sharing options...
compbuild Posted November 28, 2006 Author Report Share Posted November 28, 2006 Anyone? even just advice on how to replace the MAF sensor Thanks Link to comment Share on other sites More sharing options...
benjie Posted November 28, 2006 Report Share Posted November 28, 2006 Take the maf sensor off, if the car runs ok, then the sensor is bust. It's an easy procedure I think, buut having never done it I'm not 100% sure! Link to comment Share on other sites More sharing options...
sidlad Posted November 29, 2006 Report Share Posted November 29, 2006 Hi don't know much about the technical stuff myself...but if you look back at the treads about LIMP mode and such like there is loads of info about MAF sensors and their replacement. Link to comment Share on other sites More sharing options...
compbuild Posted November 29, 2006 Author Report Share Posted November 29, 2006 Thanks guys Link to comment Share on other sites More sharing options...
compbuild Posted February 13, 2007 Author Report Share Posted February 13, 2007 Update in case anyone has the same trouble, Got the car on a diganostic tester (VAGCOM?) and it said the MAF sensor needs replaced, disconnected the MAF and the car is running better but still very flat, it was also giving and overboost error, any idea what that might indicate? Link to comment Share on other sites More sharing options...
Rustynuts Posted February 13, 2007 Report Share Posted February 13, 2007 Replace the maf first, then see what else you get faulty. The maf could be causing your overboost fault due to not reading the airflow volume correctly. Link to comment Share on other sites More sharing options...
compbuild Posted February 14, 2007 Author Report Share Posted February 14, 2007 Thanks Rustynuts, going to get one for it this week Link to comment Share on other sites More sharing options...
compbuild Posted February 25, 2007 Author Report Share Posted February 25, 2007 Update - Got the New MAF sensor put on yesterday, Totally sorted out the car, it's running like new again, very happy Link to comment Share on other sites More sharing options...
Rustynuts Posted February 25, 2007 Report Share Posted February 25, 2007 Good stuff. Link to comment Share on other sites More sharing options...
