996C4 Posted November 23, 2006 Report Share Posted November 23, 2006 I keep getting water leaking into the car from around the sunroof controls and in the dome light. I have checked the sunroof drain pipes and all seems to be well. Happens after rain or car wash but only during hard acceleration /braking (i.e all the time) then it drips in. Nothing in the footwell which I understand is more common. Thanks in advance. Link to comment Share on other sites More sharing options...
Muppet_man Posted November 24, 2006 Report Share Posted November 24, 2006 How did you check the drain pipes, only that sound just like their symptoms. They fill up, then as you brake or accelerate, the water in the pipes shots back out and you get an early bath. Have you tried slowly poring water into the sunroof gully while it's open and seeing if after about a litre or so it still seems to be draining away OK. Link to comment Share on other sites More sharing options...
996C4 Posted November 24, 2006 Author Report Share Posted November 24, 2006 Only did a small amount of water, and was draining fine, but perhaps not well enough. How would you suggest I clear them out? Thanks for your help. Link to comment Share on other sites More sharing options...
